Fuse off Battery? Positive or Negative?
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Been thanked: 2 times
Post by warmblood58 »
Noticed a black wire with 10amp fuse holder mounted to battery positive post -this should be a negative connect vs. a positive yes? I put a test light to it with ignition on and it would not light so I believe it is a negative connection, yes? Why the fuse here? Thanks! Schematic shows all red wires coming of '95 850 turbo battery so I am assuming PO installed wrong? Help!
Has thanked: 1609 times
Been thanked: 4065 times
You almost always fuse the positive side of a circuit since faults almost always occur to ground, or the negative side, through insulation failure or cuts. The only way to sort out hack wiring is to trace it from battery to the load. There are no end to the variations of bad wiring that can be done.
warmblood58
Yes, but sometimes Neg connections are fused . . . I checked. Black wire vs red and it appears to be factory. Anyone know?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Sounds aftermarket. Post a picture.
85 GLH, 367 whp
00 Insight, 72 mpg
warmblood58
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Never see anything like it from the factory, FWIW.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Nope....it's not factory.
Could be for aftermarket alarm system,aftermarket stereo system like cd player,amplifier or some other accessories.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
warmblood58 wrote:Yes, but sometimes Neg connections are fused . . . I checked. Black wire vs red and it appears to be factory. Anyone know?
Colour of wire is not an indicator of positive or negative. A negative fused circuit is only protected from component current draw, which is rare, vs. wiring failure, which is common.
That's a hack.
