2000 v70xc low fuel pressure
just put in a dolman check valve (for hard start and vapor lock) - everything ran great for about a week, then I pulled a P0300 code. Only have about 24 psi at the fuel rail. Fuel pressure holding well at 22 psi after I turn off motor and I don't see or smell an gas leaks near the filter or at the injectors so I am thinking everything is tight. Is there anything other than the pump at this point?
Fuel pump relay and wiring. Try jumping the relay to see if the pressure comes up.
- 904 Views
Last post by Biotik
- 16134 Views
Last post by Richard99
- 20 Replies
- 13353 Views
Last post by oragex
- 682 Views
Last post by v70XCSteve
- 3503 Views
Last post by oragex
