Just took this info out of vida dice
Will check with meter soon, question if anyone knows, why does my 2004, late year c70 hpt have 2 sensors, rt and lft
one affects interior temp reading, the other is same and cannot find it anywhere, any ideas?
Gauge goes to 3 dashes when left one is removed, swapped them, temp still wrong
Component Remarks
Outside temperature sensor
Resistance:
4 °C: approximately 1.2 kΩ
20 °C: approximately 500 Ω
Coolant temperature sensor Resistance:
10 °C: approximately 20 kΩ
20 °C: approximately 11 kΩ
30°C: approximately 8 kΩ
75 °C: approximately 1.5 kΩ
90 °C: approximately 900 Ω
Combustion fan Resistance in the winding between terminals: 1-10 Ω
Water pump Resistance in the winding between terminals: 1-10 Ω
Fuel pump (FP) Resistance in the winding between terminals: approximately 8 Ω
Glow plug Resistance: approximately 1 Ω
overheat protection thermostat Resistance:
Not tripped < 3 Ω
Tripped 10 kΩ
Ambient air temp
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Note: You posted your Q in the forum for model years 1992-2000. You ID'd your car as a 2004.
M1 10W-30 HM
M1 10W-30 HM
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
He's in the right place - C70's are P80 cars until 2005.sleddriver wrote:Note: You posted your Q in the forum for model years 1992-2000. You ID'd your car as a 2004.
- 11 Replies
- 8964 Views
Last post by oragex
- 1098 Views
Last post by Rscalera
- 670 Views
Last post by SuperHerman
- 12 Replies
- 1351 Views
Last post by MoVolvos
- 6545 Views
Last post by aaronlife
