Ball joint puller needed for front lower control arms?
jefflamonica
- Year and Model: 1998 S90
I'm about to replace the lower control arms on my newly-acquired 1998 S90. Do I need a special ball joint puller, or is there another way for a DIY'er? If I need one, is this something specific to Volvo, or a loaner tool from local parts store?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Often a shot on the side with a heavy hammer will get it to drop. Loaner fork from parts store will work too.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
I was able to pound one out no problem (with the help of some PB blast), the other one not so much. Was able to do it by cutting the top up, drilling into it (1/2" bit), then pounding it more with a cold punch to make it cave in on itself. Wished I would have had a fork to do the job, would have been way easier. Take care not to damage the knuckle if you decide to pound it out.
They're conic, and I believe there are small ridges on the inside for a better grip, take care not to twist the ball joint post in the knuckle.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
apollokid
- Year and Model: Volvo 940 - 1996
Yes, standard ball joint separators have a too short opening, you need a two jaws pit man arm extractor. I bought a complete front-end set on ebay for near 60€ that contains all 5 different extractors. The one I've used is the type that remember a strong two arms gear puller. It is not common.... It is easy to find on some US sites.
May be a strong two arms gear puller will work, but you have to make a adapter to hang the lower fastening of the ball joint to avoid it slips.
- 4139 Views
Last post by Tonyx
- 6756 Views
Last post by jonesg
- 11 Replies
- 3175 Views
Last post by theWIFES_S70
- 1570 Views
Last post by kahl
- 12 Replies
- 1948 Views
Last post by erikv11
