Since I bought car 10K miles ago, outside temp is off by 8 degF
Was almost going to order another, then realized I have sensor on drivers side, left near front of radiator, that makes temp gauge go to --- when removed.
The same exact sensor is on right side same place, cannot find any info about it.
I am thinking since I have heated seats and wipers on headlights, could that sensor turn on heated washer fluid like my 97 bmw?
cannot find in vida dice either, any help would be welcomed
04 c70 Ambient temp sensor
- Has thanked: 2197 times
- Been thanked: 1850 times
Try this link as I think it has some of the info you are looking for:
https://www.matthewsvolvosite.com/forums ... =1&t=74374
I have not found the part number for the sensor on the RH side of the under air dam that pokes into the radiator air-stream, but believe they may be both the same.
Neil
Neil
