1997 Volvo 855: Incredibly crumbled orginal Camshaft Position Sensor wiring
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Just wanted to share a picture of how bad the original connector was on the camshaft position sensor on my '97 855 GLT at ~184k miles. The date code in the CPS was "94" so I'm pretty sure it's the original. It was working OK but I replaced it today to help avoid future problems.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
I ran into this same issue on my '96--engine heat, plus aging plastic.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
How does CPS work?
- Has thanked: 2199 times
- Been thanked: 1851 times
Wow, pretty toasty looking cable and plug.
- jreed
Agreed. I was surprised how brown the plastic was on the outside -- just like toast or a roasted marshmallow. When new, the connector is bright white. I think if I had waited too much longer the connector would have fallen out of the female socket.
Kridder08
- Year and Model: 1998 V70 GLT
- Has thanked: 9 times
This went out on me today - after sitting over night - would not start. Code 0340. My plug looks almost the same - fried -on a 98 V70, 165K. Should have been easy to fix but it is about 20 degrees out and all the vacuum hoses are hard as rocks so made it difficult to get to the sensor bolts. New sensor $130.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Good you got it fixed! I replaced the sensor a while back as preventive maintenace, and surprisingly the connectors were okay on both my 94 and 96
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 2599 Views
Last post by Luzanov345
- 1957 Views
Last post by RickHaleParker
- 229 Views
Last post by perhss70
- 1408 Views
Last post by cn90
- 533 Views
Last post by jackissocool
