Ok, I give up. Why is it still overheating!?
98 v70 turbo awd. New TD0419t turbo with stage 3 ARD tune, timing belt done by PO 15k ago. Unknown (but assumed) they did water pump.
I have replaced: Thermostat, ECT sensor. I have filled up the reservoir. Warmed and cooled like 4 times until it stopped getting lower. I did multiple pressure tests, reclamped a few hoses until it would hold 20psi (about double what you need to try) for an hour+. Tightened a few leaky hoses which hold now.
So now, it will be fine a few days, coolant won't be any lower at the end of the day, but then on day 3 of commuting (twice this has happened) it will suddenly have a coolant loss, then even after topping up at work will be overheating by the time I get home 45 mins later. And once cooled it will be empty in the reservoir (but some may have boiled out).
I have left the pressure tester on when running and it doesn't increase, therefore the head gasket is not leaking (at least not badly)
I took the new thermostat back out, it opens around 190 on my stove.
I cranked for a couple seconds with the thermostat cover removed, coolant shoots out so the pump works.
My OBD says temps range 190-220 max after a long turbo run.
The engine fan works, though not sure what temp it's supposed to come on at, I'd assume sooner.
I'm using basic green coolant (safer for aluminum than orange). Does that boil at too low a temp in these?
WTF!?!
Still overheating - 98 V70 T - sudden coolant loss
- Been thanked: 4064 times
No traces of cooolant anyhwere in the engine bay??
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Combustion Leak Detector sometimes auto parts stores have loaners
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
cuhfs wrote:Combustion Leak Detector sometimes auto parts stores have loaners
Best answer so far!
If you can't see any coolant, and it doesn't smell in the cabin and the carpet is dry, it's likely going out the tailpipe
'00 S70, '04 S60 and the never ending quest for Stage Zero
Since that post I have ALSO done the timing belt, water pump, radiator, heater core, OEM thermostat and blue coolant, coolant reservoir and cap.
Guess what? SAME F'ing PROBLEM!!
It seems pressure will build up in the cooling system and then cause the cap to spit out fluid. It won't do it the first 15 mins or so, but at some point, the system gets charged with pressure. So there must be a small head gasket leak or crack in the block that on;y leaks when hot. F this car
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
broken08 wrote:First $2000 takes it.
$400 and you have a deal.
- Has thanked: 311 times
- Been thanked: 817 times
I agree this makes the most sense. This problem would *absolutely* give a positive on the combustion-gases-in-the-coolant test.broken08 wrote:.... So there must be a small head gasket leak or crack in the block that on;y leaks when hot. F this car
- 453 Views
- 3394 Views
- 615 Views
Last post by volvolugnut
- 469 Views
Last post by Faust
- 883 Views
Last post by 93Regina
