Battery warning light
Gravesie
Year and Model: 1996 850
Post by Gravesie »
My battery warning light comes on for a few seconds after shutdown. The alternator is all good and the battery is brand new
Has thanked: 1611 times
Been thanked: 4072 times
That's probably an alternator fault or a ground ( earth) fault somewhere. There are many earths on these cars and they do go bad.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
When the engine doesn't turn, alternator doesn't produce voltage.
85 GLH, 367 whp
00 Insight, 72 mpg
There is a cut-out switch in the alternator that has to open when the engine is turned off on most cars, I don't know Volvo specifically in this regard, though.
Check battery cables
Check ALL grounds - there are a lot of them.
Even if alternator is putting out good current, you might need to replace it, or if you are good with electrics, disassemble and replace brushes/switches/rectifier - or send it to a good electric shop.
