Is Mixing Motor OIL safe? 1997 850
christhegamer
Year and Model: 1997 850
Post by christhegamer »
Hi, when I took my car to Midas for a oil change they put 5W20 motor oil in my car but I noticed the oil was running low so I added 10W30 motor oil to it, Is it safe to mix 5W20 and 10W30 motor oils? Will it cause any damage or is it ok to mix motor oil. Thanks !
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I have had to do it on occasion with no side effects. Sure beats having no oil.
Has thanked: 1609 times
Been thanked: 4063 times
As long as you don't mix Mobil and She'll, you'll be ok.
christhegamer
I am not sure what kind of oil MIDAS put in it when I did a oil change they just said 5W20 on the sticker, and I added some 10w30 Oreily auto part brand.. How do I know when its mobil and shell? :( I hope they didnt put mobil or shell I did a regular oil change I did not do a synthetic oil change is mobil synthetic? Or shell synthetic? They put 5w20 regular oil and I put 10w30 regular oreily auto part brand oil in...
Sorry, it's an old car talk joke. shell+ Mobil gives Schmell.
You can pretty much mix engine oils with impunity
christhegamer
Oh you were just joking? LOL! You got me! :P Scared me there.. lol :P
christhegamer
Thanks for all your help guys and helpful information.
kahl
Post by kahl »
Well I read on the internet that if you mix Dino oil and synthetic it will short out your muffler bearings.
christhegamer
you said mixing Dino oil and synthetic it will short out your muffler bearings? I am sorry i dont understand where did you read that and what is dino oil? It will ruin your muffler if you use dino oil and sysnthetic please if you could explain it better? Thank you.
Has thanked: 2196 times
Been thanked: 1850 times
Someone is pulling your chain again!
No worries mixing oils. Personally I don't like to use too thin an oil with older engines as they ran larger tolerances so it is harder for the engine to get decent oil pressure and they tend to use more oil. I now prefer to use synthetic oil when I can as it works better for my cars in the low temperatures we get here in Canada. Use what the handbook recommends for in terms of viscosity for the temperature range your vehicle will be used. Whether you use dino oil (conventional), semi-synthetic or full synthetic is up to you and your wallet. Regular changes are what are needed and more so if you drive the car hard.
