97 850 R build
biohazrd76
- Year and Model: 1997 850R
Need some advice. I'm beginning to get serious with my 850 now that spring has come. I have been told this car has 15g turbo. I'm looking at ard 18t compressor wheel and housing, as well as the exhaust turbine or exducer. With this I would also install a new wastegate actuator, I have seen in aftermarket, like forge brand. The Volvo part is in the 400 $ range
. So is this too much money to put into an old turbo. Should I save up and buy rebuilt 18t unit complete. I'm comfortable working on my own. Just asking the experts again. Also currently when the car is driving and boost is at "target" it waivers the power . Rpm should be steady but goes up and down a tiny bit. Hitting full boost then off and on during hard load and boost is at 10psi. Any recommendations
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
BPV or TCV might be acting up.biohazrd76 wrote:Need some advice. I'm beginning to get serious with my 850 now that spring has come. I have been told this car has 15g turbo. I'm looking at ard 18t compressor wheel and housing, as well as the exhaust turbine or exducer. With this I would also install a new wastegate actuator, I have seen in aftermarket, like forge brand. The Volvo part is in the 400 $ range. So is this too much money to put into an old turbo. Should I save up and buy rebuilt 18t unit complete. I'm comfortable working on my own. Just asking the experts again. Also currently when the car is driving and boost is at "target" it waivers the power . Rpm should be steady but goes up and down a tiny bit. Hitting full boost then off and on during hard load and boost is at 10psi. Any recommendations
ugh smh 850 Turbo fridge
- 5747 Views
Last post by biohazrd76
- 1885 Views
Last post by efkaba
- 1684 Views
Last post by erikasambrozas
- 141 Replies
- 9891 Views
Last post by foggydogg
- 12 Replies
- 3255 Views
Last post by metalslug
