Purchased a set of Sachs. Look easy enough to replace. Saw a tutorial on youtube for doing them on an S60. That was easy as easy gets. But my V70 has to be different. How in the world do I get access to the top nut? It's half buried under a piece of sheet metal so I can't put any tools on it. Part of me just wants to cut the metal because I only need a half CM to get to it. But I know I'm looking at this wrong so I figured I would consult you first.
Any tips are greatly appreciated. Thanks!
Hints for rear shock replacement on 2003 V70 AWD
DEMonte1997
- Year and Model: 2003 V70
Reason: Clarified title - please, no CAPS or HELP in titles - read the rules
2003 V70 | 2001 Regal turbo | 2002 Sierra Denali
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe with an offset key? I also use an adjusting wrench just like in the picture with a torx socket on the rod https://www.matthewsvolvosite.com/forums ... hp?t=28318
The lower bolt has a nut that is usually welded to the chassis, so the ratchet will go on the bolt side. I tried to loosen the nut and my back didn't like it
DEMonte1997
Thank you for the quick reply. Mine looks a lot different than the earlier models.
In real life, the nut is half buried under a piece of sheet metal. So I can't get the torx socket on the shock shaft and cannot get a wrench on the nut. Never seen anything like this...
Any further suggestions?
DEMonte1997
Here's a photo. Hopefully it posts okay.
DEMonte1997
Ah. So that means I have to compress the spring to get the shock out. Not sure why I thought it would be easier but not the end of the world. Thanks for the responses.
- Has thanked: 2199 times
We just had our 06 XC70 rear shocks and springs replaced. 1 shock was getting weepy but one of the springs was actually broken!
Springs are the cheap part, and if you don't have 4C suspension like the XC and R have then thank the car gods as they are stupid expensive. As it takes the same amount of labor to swap the shock and spring, then do both would be my suggestion.
- 1767 Views
Last post by MoVolvos
- 1268 Views
Last post by SuperHerman
- 3630 Views
Last post by Jonboy74
- 12 Replies
- 8747 Views
- 2404 Views
Last post by Scottyv
