SC-901 Tested & Working
OhSoDubious1
Year and Model: 1998 V70 T5
Post by OhSoDubious1 »
Scored this radio to instal into my 98 V70 only to find out I need the Amp also,I dont have the amp ..so I went a different route...
I pluged it in an it turned on ,No sound,even threw in a CD an watched it Start playing Only with out the sound..again it need the amp to work properly..Comes with the 3disc cartridge ..also with CODE
Escapenthanightmare (at) gmail.com
$150
Has thanked: 2211 times
Been thanked: 1852 times
You also need the cable to connect the amp. These items can usually be found at PnP places. I always have a laugh when I find people have pulled the radio and find they don't work without the amp. If I see the amp and cables I pull them and now have a stash of them. Amps are still available but cables are obsolete.
gordo850turbo
Year and Model: '95 854, S70 '11C70
Post by gordo850turbo »
Do you have any speaker cables that go from the SC-901 to center speaker?
I don't have any cables for this. That is for the center Dolby unit? In the 2-3 years I have been going to our local PnP's there has never been a car with the Dolby units. Guess people in this area were too cheap to buy them!
I know Chapman Motors on Vancouver Island had some cars with the Dolby units in them, so maybe worth trying them, or vandsautodismantlers in California, or Erie Vo-Vo in the East.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
The center channel speaker cable actually runs from the HU to the speaker.
It plugs into the green connector on the SC-900/901s. On some cars, it may
also have other leads on that 5 pin plug.
gordo850turbo
Yes, that is the cable I am looking for. It plugs into the green connector on the SC-900/901. I bought a center speaker off of ebay from someone parting out a C70. I told him I would only buy the speaker if the wire came with it. He sent the speaker with a wire, but it didn't fit in my SC-901. :( I'm not sure what happened. I don't think there are any other stock HU's that have a center speaker channel. I think he might of just grabbed another speaker wire out of the car thinking it didn't matter.
cbburtraw
Year and Model: 1998 S70T5M, 01 V40
Post by cbburtraw »
Neil,
Do you have any amps to sell? I need one - have the cable and bracket but the amp I had before went up in smoke. (This is for behind the dash version).
Thanks!
psvolvo
Year and Model: 1998 V70 M56
Post by psvolvo »
Neil,
I just recently found a ( mostly working ) 901 and need the under seat amp and wiring to the amp...Do you still have any of these left?
Thanks,
Chris
Hi Chris I do have 2 tested and working amps and also the cables to connect. What is your problem with the SC-901? PM me and we can figure this out.
Neil (scot850)
