Engine won't pass 4000 rpm
Ethan Slatnia
Year and Model: C70 2.4 T 1999
Post by Ethan Slatnia »
Good evening everyone . I had recently an issue with my 99 C70 2.4 T , the issue in question is when I'm on the freeway my engine won't pass 4000 rpm even if I'm doing over a 100 mph . My CEL is on but for a vapor issue from the gas cap . I heard that it could be a Catalytic converter , but I have no idea .
Any help or answer please ???
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It could be a bad tach. Just revving in neutral will it go above 4000?
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
I had a problem on the high end, turned out to be plug wires. At the higher rpm's, they just broke down. Worked fine at lower power. Changed the wires, and fixed it.
Also, is it possible that you have a waste gate leak?
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Ethan Slatnia
Thank you for all of you guys for the quick response.
Lee, even when.im at P the engine won't pass 4000rpm.
Pkc303, I'm sorry what do you mean by waste gate leak? Is it that serious ??!
pkc303
Has thanked: 1 time
Post by pkc303 »
Mine will not in Econ mode, but does in Sport mode. Do you have a switch to change modes?
I'm not familiar with the C70, so I may be way off here. I have 850R's
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
N/a cars will NOT rev past 5000 rpm in neutral,should be the same for turbo ones too.It's a safety feature because it's not good for the engine.
It certailnly must rev past 4000rpm at idle.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1609 times
Been thanked: 4064 times
A very good friend tells me a 1999 T5 M revs 3750 at 100 mph.
