98 s70 egr making tapping/clicking noise on start-up.
Clockboy
- Year and Model: 05 xc70, v70 2.5t 06
- Has thanked: 2 times
I've noticed a clicking sound when starting the car the last few times. I tracked it down to the what I believe is the egr planted on top of the turbo. When I put my finger on it over the top hole the tapping would stop. The last time it happened, today, it lasted for about a minute. I recently changed the front O2 sensor and the induction hoses. Is this a sign that it needs cleaning or is on its way out? Or is it a symptom of something else?
- Year and Model: Many Volvos
- Been thanked: 76 times
The EGR, if you have it, is on the intake manifold and not really near the turbo. I think what you might be describing is the SAS valve if it goes into the exhaust manifold and looks sort of like a mushroom. Search around for cleaning methods but I just do a SAS delete with a diode and forget about it.
Clockboy
Thanks Lee. You are of course right. II do not think my car even has an egr. I should have known that was the sas valve since I had tracked down an sas code to the torn vacuum connector on it last year. I had considered deleting it when I was having the problem and it seems the Swedish beast has forced my hand.
- 57 Replies
- 27971 Views
Last post by shadetree_v70
- 3858 Views
Last post by 800artfreed
- 550 Views
- 600 Views
- 574 Views
Last post by Chrisg13
