2005 S60 AWD: Steering limiter
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
Since I've had the car (Sept 18, 2015), tight turns cause a rubbing on the inner fender. 17" "Thor" wheels. Just went shopping for tires and noticed a line that says "Need steering limiters from Volvo installed to prevent rubbing on inner fender" (loose quote). Possible that someone removed them? Are they adjustable? Very unsavory for a premium car to make scrub noises pulling into Walmart, Family Dollar and such.
Still irritated that a 28" box International truck has a tighter turning radius by a foot.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
JRL
- Year and Model: Several
- Been thanked: 16 times
There are 3 different sizes of limiters
These cars were never designed for large tires
Tire brands are different widths (of the same size tire), which is why Volvo used Pirellis as the OEM tire. They seem to have the narrowest tread
Run 5 mm spacers on the front wheels and usually that cures rub issues
A 28' box truck is RWD
- 1244 Views
Last post by jbkeene
- 510 Views
Last post by NineEleven
- 658 Views
Last post by oragex
- 812 Views
- 13 Replies
- 2139 Views
Last post by misha
