interchangeable parts
clayfield12
- Year and Model: 1994 850 turbo
I'm looking to sell my 94 850 turbo as a parts car and a friend of mine had a 98 v70 turbo. Im wondering if the two cars parts might be interchangeable.
Bluevanacd2005
- Year and Model: 1983 760
I'm thinking it depends greatly on what parts. Pretty sure the turbos have different exhaust flanges (one angled and one straight).
I like curves on my women, not my cars
- Has thanked: 311 times
- Been thanked: 817 times
The exhaust flanges you can just swap over, so the turbos are freely interchangeable. Although the 98 came with a 16t and the 94 with a 15g, but they can swap OK.
Basically everything mechanical will swap over, very little cosmetic/body/interior will swap over exactly.
Brakes, heater core, cooling system, alternator, relays, transmission, engine, engine mounts (except maybe the front one), radiator, axles, suspension, all of those mechanical parts are the same. Most sensors are the same. Minor differences in the intake manifolds, PCV setup, ABS module, battery cables to the fuse box, speed sensor, a few other places.
- Has thanked: 316 times
- Been thanked: 531 times
Didn't '94 have the conical flange?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
other determining factor for motor is whether 98 is HPT (similar to 94) or LPT, whole different motor.
Current Volvos:
Yes, that would be the T5 (HPT) or GLT (LPT). All that was specified is that the V70 in question is a turbo. Most parts between the GLT and T5 are interchangeable, though.FLXC90 wrote:other determining factor for motor is whether 98 is HPT (similar to 94) or LPT, whole different motor.
The flanges separate from the turbos, so it doesn't matter.bmdubya1198 wrote:Didn't '94 have the conical flange?
To be honest I don't keep track of which flange on which car, I look it up when I need to know (but I think you are right !
Good call I was assuming a 98 T5, my mistake, could easily be a GLT or XC (both LPTs as you pointed out).
That's true, you can just transfer the compressor side of it.erikv11 wrote:The flanges separate from the turbos, so it doesn't matter.bmdubya1198 wrote:Didn't '94 have the conical flange?
To be honest I don't keep track of which flange on which car, I look it up when I need to know (but I think you are right !). To swap a turbo, use the flange in the acceptor car (leave it in place or pull the whole thing out for a swap), move over just the turbo from the donor car, no fitment issue.
"The compressor side" is the whole turbo. The flange is a separate piece. If you buy a turbo it will not come with a flange, etc.
I guess I'm just used to seeing them for sale used. That would make sense.
- 1415 Views
Last post by MadeInJapan
- 2172 Views
Last post by June
- 3087 Views
Last post by skloon
- 19 Replies
- 4975 Views
- 2840 Views
Last post by MoVolvos
