Moving along
Marty27
Year and Model: 1997 850
Post by Marty27 »
Got the radiator installed today, that went well. Now if I could just figure out the knock sensor code and cruise control, that would be great.
Has thanked: 2198 times
Been thanked: 1851 times
Check the vacuum pipework for the cruise control. The rubber parts fail.
Knock sensor try just a clean of the connector. Try the simple stuff first.
Marty27
Post by Marty27 »
The vacuum seems to be fine, tested that. And I guess I'm going to pull the intake this weekend to check the knock sensors.
dosbricks
Been thanked: 4 times
Post by dosbricks »
I think there was a TSB for 1996 (maybe '97 also) because years ago I had an updated wiring harness installed when I got a knock sensor code. Last year when I had my engine out to do the RMS, I found this to be about the only place where it was possible to get wire connectors switched. Since you swapped engines, if you have an extra bundle of wire that attaches to a white bracket, you may have this extra harness. If so check for orientation of the wiring. Otherwise, disregard all of the above. :|
Marty27
Post by Marty27 »
Coincidentally, I installed a '96 engine. The knock sensors looked the same, except for the location of the connections. So I had to use the ones that were in the car originally. The car is a '97.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Check that the rod is connected to the gas pedal
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I had loose bolts on both knock sensors (one was almost finger tight) which lead to codes on a 2001 XC70. Taking intake off was the only access.
Has thanked: 1609 times
Been thanked: 4065 times
Don't over tighten them though, the spec is really low. If you crank on a 6 inch socket handle, you will overtorque
Marty27
Post by Marty27 »
Well, it turns out that the cruise control actually does work. I guess I just assumed there would be some kind of indicator light.
Even on the 1999 the cruise light only comes on during engagement, it doesn't even come on during lamp check in key Pos II.
Evan listed on this during his cruise tribulations
