Transmission won't engage :(
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Volvodog77
Year and Model: 2003 xc 70
Post by Volvodog77 »
:roll:
Hello...what a great site! A valuable resource
For all of us who love our Volvos.
I will cut to the chase:
The other day I was at a green light...in my
'03 xc70 (254,000km).I pressed on the gas pedal...the rpm
Went up, though the car would not go,
The selector was in Drive...
I placed selector into Park, turned the ignition off, waited a few seconds, and re-started it,
Put car in Gear D, and this time the transmission
did engage, I was able to get it home, though
It was slipping...the TSR light has been on for awhile...and Reverse has been finicky since I bought the car 2 years ago...I did a flush last year, (Gibbon's Method)
This is the first time the transmission has done this...does anyone have any ideas on what could cause this to happen...and possible solutions to fix it...
Thanks for Reading.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Check the level...these cars will buck and do strange things and not engage gears if the fluid is low.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, the easiest is to check the level...30+ min. driving, flat surface, engine at idle in P, need to see a thick smear at the hot mark.
Also check engine mounts and axle shaft/end bolt
Volvodog77
Hi thanks for the replies...I did a gibbons flush with 11 liters of t
And still no results...another symptom I didn't mention earlier was I could smell burning transmission fluid when trying to reverse...any help on this would be this would be great...thinking sadly it may be to time replace the transmission or say bye to the car :(
Has thanked: 1502 times
Been thanked: 3813 times
You can source a used transmission a lot cheaper than a new car if the rest runs well.
Drop the ATF out of the pan and evaluate for burned stuff to get an idea of what's going on in that trans
