06 S80 drive shaft removal ideas
ifallss80
Year and Model: 2006 S80
Post by ifallss80 »
Hello,
I'm in the process of doing some major work on my 06 S80 AWD. Trying to drop oil pan which means I need to remove rear diff, (bevel gear stripped so repairing that) which then I need to remove the rear drive shaft too. I have all the allen head bolts removed from front and rear, carrier bearing loosened up and hanging and now I'm trying to get the ends loose. How does one go about getting this thing out? In desperate need of advice so I can continue on with the project.
