Idle up and Down, also rough
ADriggs26
Year and Model: 2001 s60
Post by ADriggs26 »
I have a 2001 s60 with 170,000 miles on it. I've had an idle that goes up and down a few hundred RPM when idle. Also when the RPM drops, the idle is rough. Also there sounds like a wobble or loose pulley when the car idles. It drives great and I have no problems other than this. Help please, it's driving me crazy. Timing belt was replaced around 100k.
BrandoBob
Year and Model: 2002 S60
Post by BrandoBob »
As a possible guess,
....you may want to investigate cleaning your throttle body. Clean it carefully and gently as the bore is teflon coated and using throttle body cleaner will melt it and a wire brush will create faster carbon buildup in the future. the throttle body clean is a temporary fix, if thats your issue, but it will fail in time and have to be replaced with another faulty unit or an improved contactless throttle body.
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
Maybe try some Techron Fuel Cleaner if it persists. Pull up to a gas station, empty a bottle in, and fill up your tank. It may run better.
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Can you do a live scan, it may be dropping a cyl, intermittent spark etc.
