Hello all,
My tensioner started to make noise and I am looking to replace it. Tried to find a write up but couldn't find anythig, It doesn't seem that complicated, I'd appreciate it if you can give me some tips or some guidance beforehand.
Thanks.
Drive belt tensioner replacement - 02 V70 2.4T
neworleans
- Year and Model: 2007 S60R
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Here is a hint:
Replace timing belt tensioner
Depending on how recently the timing belt job was done, you may want to change some other components besides the tensioner itself, since you are at it.
If you look up 'Timing Belt' in the forums Repair Database, there are quite a few useful write-ups
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I believe neworleans is talking about the accessory drive belt, not the timing belt.
Just make note of how the belt is routed so that you can get the next one on properly. The tensioner, as you have probably figured out already, is spring loaded and can be pulled away from the belt with a large torx bit with some sort of long handle or cheater bar. Some of the tensioners have a hex bolt in the center of the pulley that you can get on with a socket and breaker bar to pull the tensioner back. The biggest issue I find with R&R'ing the belt is the tight quarters you're working in.
precopster
- Year and Model: Lots
- Been thanked: 128 times
There is either a 14mm bolt or a torx 40 securing the tensioner pulley. Just a standard thread (not reverse) and some thread compound on the bolt.
If you want to remove the tensioner as a whole there are 2 x 12mm bolts holding it in place.
neworleans
Thank you guys, the link below is what I found at FCP but seems like there is only one bolt hole to install, is the other one hidden?
https://www.fcpeuro.com/products/volvo- ... er-99-plus
chrism
If you look at both views of the tensioner in the FCP ad, you'll see that there are actually two mounting holes. (One hole visible in one photo - the other hole visible in the other photo) One of the holes is further away from the business part of the tensioner than the other hole is.
http://www.autopartsapi.com/eEuroparts. ... 11abbf.gif
Hope this helps.
Hope this helps.
neworleans
Thank you so much, perfect!
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
If it is making noise (I.E. the bearing), there is an option to just replace the pulley and leave the tensioner in place. If it is the 14 mm hex style, you can just unscrew the bolt and then pull the old off and on with the new. Tightening this bolt can be a pain, as the spring tensioner moves. I'd recommend a dab of thread locker (blue). If it is the newer style and there is no 14 mm bolt to be seen on the pulley, then you have to take off the plastic cap in front to expose the large torx bolt. Add some thread locker as it is installed.
This can all be done from the top and was a pretty simple effort for me, but I've been building cars for 40 years, but I can see someone of limited experience doing this. It's all about tool selection. Mine was the 14 mm bolt, and I used a 14 mm ratchet wrench that had a slight bend offset. I put a pipe over it then pulled to the right to relieve the tension on the belt so it could be removed 1st.
Good luck, please let us know how it goes!
Checksix
Checksix
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
- 5061 Views
Last post by jimmy57
- 839 Views
Last post by fitz548
- 4952 Views
Last post by Slidfungus
- 305 Views
Last post by RedBrickCollector
- 2312 Views
