Clicking when Revving Engine
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Been thanked: 2 times
Post by warmblood58 »
I noticed the other day while revving engine slightly that engine rocks back and there is a clicking sound. Research tells me that this is most likely lower passenger side engine mount. If confirmed, best aftermarket mount and is this mount easy to change? Thanks!
huzzsaba
Year and Model: 2004 volvo xc90 2.5t
Post by huzzsaba »
Best brand is hutchinson I believe. Not sure if its oem or not, but they seem to hold up well.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Is the torque mount bushing on top intact? By far the most common, broken mount.
If you are wondering about the front engine mount (lower passenger side), get a look directly at it. The car will need to be up in the air, then pull the passenger wheel. Is the mount intact, or is the engine sitting on the subframe? Hutchison makes the hydraulic mounts (and quality ones!), not sure if they also make that one. For a 95, I like Lemforder on the front mount.
warmblood58
Thanks all!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
