Hey all, Im having a problem with my 760.
The car has been sitting parked for about 9 months now. I started it up once or twice when i remembered to. Then back in December I think? I tried starting it up again and it needed a jump. The battery itself was AT LEAST six years old if not older. I let it sit for 30-45 minutes and shut it off, thinking that was good enough.
Jump to today, Im leaving on a couple month trip and wanted the wife to have a second vehicle for an 'emergency situation/ just in case'. So i decided to go and get a new battery. Installed the new one and went to turn the car on.
Now the car cranks and the belts are moving, sounds like a normal cranking to me. However the car will not start. I thought maybe this battery needs some extra juice and tried jumping it. Same thing.
Im guessing *hoping* maybe its the fuel? 9 months of sitting? I've been thinging about going back out to get a syphon pump and pumping out the gas, replacing it with a couple gallons of new stuff.
Any ideas would be great. THank you
1987 760 Turbo No-start
brandon7219
- Year and Model: 1987 760 Turbo
Well i figured it out. really stupid silly and a huge overlook after battery install on my part. I went around checking lines/hoses, filled up liquids that needed filling (oil, antifreeze, power steering). Still nothing worked
It was that Bosch ignition module plug thats right next to the battery. I must have hit it and unplugged it on install. I noticed it today when i went out to check the igniters. when the igniters checked good i went to hook up the Negative side of the battery and saw that plug just dangling. Hooked it back up and the car started right up.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Leaving a vehicle parked in a garage, it can sit for longer periods without gas/alcohol separation. But, if not run periodically, injectors have been known to gum up, and stay closed.brandon7219 wrote:Well i figured it out.
It is well known that "The storage and stability of ethanol blends are special issues due to ethanol’s affinity for water and the risk of phase separation."
I have a vehicle that has been sitting several years in a machine shed, and so far no issues; but every several months, it is started/driven.
Leaving a vehicle parked outside for months, on an empty tank, is asking for trouble.
- 3029 Views
Last post by jimmy57
- 11 Replies
- 2620 Views
Last post by robin_740
- 359 Views
Last post by Richiebuonanotte
- 5234 Views
Last post by Salomons Driveway
- 1409 Views
