ETM replacement and LESSONS LEARNED
Checksix
Year and Model: V70 T5 2001
Been thanked: 2 times
Post by Checksix »
For me the most difficult part of this job was releasing the plastic intake from the ETM and refitting the banjo bolt at the manifold.
I did things a little different than instructions I had read. I unbolted the ETM from the manifold and left it attached to the tubing when disassembling. Getting to the 4 bolts was easy from beneath after removing the air "dam" that fits just behind the bumper. It has 2 each 10 mm bolts and 2 clips that release with a screw driver. That took only about a minute and for me was worth it. At this point I had not pulled the radiator fan, but did much later.
After the manifold was removed, I pulled the ETM from the plastic tubing by heating it with an industrial heat gun. I do think a good hair dryer would also work, but would take more time. Adding some heat made this very simple.
For reassembly, I attached the ETM to the manifold 1st. I only snugged the bolts and tightened after the manifold was in. Prior to putting in the manifold, I put in place the banjo bolt. I kept it in place by using pliers and slightly deforming the upper copper washer so it couldn't fall out. I put on the new intake manifold gasket and put in the 3 lower manifold bolts a few turns. With the intake clamp in place I then heated the plastic intake pipe until it was soft. I hung the manifold on the 3 bolts and then pushed the plastic intake on from the front (this was why the radiator fan eventually came out so I could have working room). This went on so easy, I thought I didn't do it! I tightened up the clamp.
On to the banjo bolt. What a major PITA!!!! If I had to suggest to engineering on how to make this easier I'd suggest making the bolt thread free for the 1st 1/4 to 3/8 inch so it would better self align. If I ever do this again, you can bet I'll put on a nut, then grind off some thread and take the nut off to reform the threads. Anyhow, I did get it on. Along the way I broke the hard plastic tubing that goes from the banjo bolt to the oil separator. To fix this I spliced on some silicon tubing I had that was thick walled and the perfect inside diameter. This flex joint in the middle actually helped make the alignment easier. I still had a hard time. What I found was to keep the manifold low, and as you hand tighten the bolt, as soon as there is resistance past finger tight, use a shorty 17 mm open end. This got it started. To finish tightening I used a ratchet wrench that has a flex angle on the end (Craftsman #42482).
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
Has thanked: 1609 times
Been thanked: 4063 times
The coolant banjo bolt on the 1999-2001 PCV is destined for one of the "Mechanics hell" entries, indeed. Tough job.
I did mine on my PCV work by attaching it and then attaching to the oil separator with the intake manifold installed.
Removing PS pump and alternator helps too.
Checksix
Post by Checksix »
After I had gotten mine all together, I noticed I'd forgotten to replace the outer tube that cover the smaller tube. Not sure of its purpose, but if I was to guess to help keep things at temperature so it doesn't condense out and plug the small openings. I was able to pull out the small tube at the oil separator and slide on the outer tube. However getting the tube back into the connection was a bear. Yes, I did finally succeed by using needle nose pliers and reaching in under the manifold.
Jerry
