Volvo V50 2007 Immobiliser Problem
Hi, I've recently had to replace the ABS Pump and the module as it was sent off to be fixed but i was told that they can't fix it and it will have to be replaced. I've fitted another unit from the same model but now i've problem with the immobiliser and the car won't start. Is there any way to code the module to the ECU? It's a 2007 Volvo V50 1.8 SI. Thanks for help...
- Has thanked: 17 times
- Been thanked: 35 times
Moving this to the P1 S40/V50 section (as this section is for the older models)
- 2307 Views
Last post by MadeInJapan
- 6434 Views
- 1679 Views
- 935 Views
Last post by yagger
- 707 Views
