So the power radio antenna is not going down all the way. I ordered a new antenna mast and saw some do it yourself videos on replacing the antenna. Is there a way to remove and install the antenna mast with out removing the entire motor housing?
Please let me know.
Thank you.
1996 850 Power Radio Antenna
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
No. It's simple though so you shouldn't be too concerned. Is there a reason you want to avoid taking the motor out?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sure, you can remove the current one, leaving some of the old mass cord in there. Then install the new one and have it hung up about 3/4 the way down.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If isn't going down all the way, the mast is probably bent or in need of lubrication.
The first thing that I would do is lube it up. Using a folded rag or paper towel, douse
the mast liberally with TriFlow. Run it up and down a few times and see if it gets
any better. You may get considerably more life out of the existing mast.
As far as broken parts inside? If the mast goes all the way up, then the geared nylon
strip inside is intact and you can swap in a new mast pretty painlessly. There should
be instructions with the new mast. If not, just loosen the nut at the top, have someone
raise the mast while you're there to pull it the rest of the way out.
Pay Close Attention to which way the teeth on the nylon tail are facing when you pull it out!
Insert the new one with the same tooth orientation and ask your assistant to turn the radio
off to "lower" the antenna. Feed the tail and the mast until it grabs and let it pull the new
mast in. It will stop automatically when it needs to. Tighten the nut. Rock Out.
Thank you so much!! I swapped out the antenna and you are absolutely right in terms of inserting the new mast painlessly. Everything was intact, just that it kept getting stuck for the last 1/4. Appreciate your help. No need to remove the motor or anything!
- 2947 Views
Last post by mika
- 12 Replies
- 6593 Views
Last post by mrbrian200
- 2032 Views
Last post by Ben850
- 469 Views
Last post by E Showell
- 1770 Views
