does anyone have suggestions?
It can go for days without stalling.
It will rev up at a stop light on its own, so I need to put my foot on the break harder to prevent taking off.
Sometimes while shifting gears, mostly to reverse.
Car smells like gas when windows are rolled down.
other people say there's an air leak by listening, but I can't hear it. I sprayed starter fluid on the hoses to see if the rpms would go up but nothing happened.
'84 stalls unpredictably
Mr Sabetodo
- Year and Model: 85 volvo 245
- mydamnvolvo
- Year and Model: Lots
Does the temp gage fluctuate when it surges?
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- mydamnvolvo
Not necessarily, he could be smelling fumes from the engine compartment. If the temp gage is fluctuating, that means that the coolant temp sensor is not receiving the right temperature.lummert wrote:If you can smell gas you have a leak of some type.
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
that gauge has no relationship to ECU's temp-sensor.mydamnvolvo wrote:If the temp gage is fluctuating, that means...
Increased idling means additional air is coming into intake manifold, so the logical suspects,
1. Brake's hydrovac unit not fit for duty, diaphragm slit
2. IAC, if throttle switch is sending correct signal to ECU
3. Intake manifold, throttle body, sucking additional air
4. Fuel injectors' o-rings need to be replaced.
He says, "other people say there's an air leak by listening," so find it.
- mydamnvolvo
that gauge has no relationship to ECU's temp-sensor.93Regina wrote:mydamnvolvo wrote:If the temp gage is fluctuating, that means...
But, if the car is reading an abnormally cool temperature, the car will increase its idle to increase the temperature of the engine, resulting in stalling because the car starts to overheat. The temperature gage would fluctuate because the car would read cool, then overheat, then off.
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- mydamnvolvo
If the temp gage is not fluctuating, you may have a crack in the intake gasket. Try spraying carb cleaner on a joint where the manifold connects to cylinder head.
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
- 16 Replies
- 3313 Views
Last post by styoung94
- 13 Replies
- 2505 Views
Last post by a061469
- 1282 Views
Last post by elvee55
- 18 Replies
- 5882 Views
Last post by regent
- 1066 Views
Last post by HurricaneLuis
