My door locks sometimes don't go up and down if in hot weather or if used repeatedly. I explained the issue in this thread:
https://www.matthewsvolvosite.com/forums ... =1&t=75316
I followed RobertDIY's tutorial on this:
Today...
1. I took out the lock in the left-rear door
2. I replaced the power lock motor's heat sensor with a flattened piece of copper wire
3. I re-assembled the lock just enough to test it on the car
4. I plugged the power lock assembly into the plugs on the left-rear door. (Imagine the lock just dangling by its wires from the door. Seems secure enough...)
5. I clicked the "lock" button on my key fob. Hilariously, I didn't secure the lock together well enough, and the motor and gears went flying out of the lock and onto the floor.
6. I put it back together again, plugged it into the left-rear door, and pressed "lock" and "unlock" on the key fob The other doors try to lock and unlock. The left rear door... NOTHING. WHAT?!
I can't find anything obvious that's wrong. If the motor had circuitboards in it, I'd wonder if I had shorted them out. But it's a stupid simple electric motor consisting of a coil of copper wire and a bearing. I can't figure out why it's not working.
Disclaimer: Sorry if this post makes no sense. I've been messing around with this for 6 hours, I seem to have made it worse than when I started, and I'm getting grumpy...
98 V70 Door lock: Doesn't work after replacing heat sensor with copper wire
- v-45magna
- Year and Model: 99 S70 GLT
- Has thanked: 2 times
Is it possible that the contacts inside were bent or broken? Earlier, I had ordered some motors off of ebay and received them before I realized the one's I ordered had the shaft coming from the wrong side of the motor. But I was able use one for parts to replace the contacts/brushes in one of my motors where I had knackered it up inside. I had to go back into the motor, but the parts fit it like a glove and fixed me right up. I'm sure it's the best motor of the four I have in the car now.
1337
- Year and Model: '18 VW Golf 1.8T 5MT
RobertDIY has an extra door lock motor that he is going to send to me!
Robert is my hero...
Now that I have (almost) completed one door and I understand how it works, I think the other 3 will go much faster.
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Last time I had that happen the latch had come apart in the door and the motor was loose from the contact pins.
1337
I inspected the motor as carefully as I could, and nothing seemed bent or out of place. But, it's certainly possible.v-45magna wrote:Is it possible that the contacts inside were bent or broken? Earlier, I had ordered some motors off of ebay and received them before I realized the one's I ordered had the shaft coming from the wrong side of the motor. But I was able use one for parts to replace the contacts/brushes in one of my motors where I had knackered it up inside. I had to go back into the motor, but the parts fit it like a glove and fixed me right up. I'm sure it's the best motor of the four I have in the car now.
- 3965 Views
Last post by jonesg
- 12 Replies
- 2787 Views
Last post by wizechatmgr
- 1680 Views
Last post by jimmy57
- 677 Views
- 648 Views
Last post by EngineeringBloke
