My 1998 V70t5 stock radio had an issue with the ribbon on the inside and while trying to replace it, I've messed up two ribbons trying to fix it.
One question:
Are the stock radios for the '98-'00 s70/v70 model cars interchangeable?
(I want to change out my stock radio for another stock radio that is exactly the same)
I know I need to call and get the radio code from Volvo, I'm not worried about that, will there be any other complications I might run into?
I've searched the forums before I decided to post and had no luck..
Thank you guys for y'alls time!
-Noe
Stock Radio Swap
Awesome! all I needed to know. Thanks!!!kahl wrote:Have done on the 98 V70...plug and play after radio code
-Noe
2002 s60 Base - 215k - KIA [08-2014]
2000 s70 Base - 170k - Traded in [2015-16]
1998 v70 t5 - 232k - KIA [2016-2018]
2000 s70 Base - 180K KIA [2018-2018]
1995 850 TURBO - 77K [2019-]
- Has thanked: 311 times
- Been thanked: 817 times
If you know the VIN of the car the radio came from, you can get the code here:
http://www.volvocars.com/us/forms/radio-code
I have a spare I would sell for relatively cheap, PM me if you want to discuss.Marty27 wrote:I'd like to replace the radio in my 850. The volume knob does what it wants to.
Or hit up the pick-n-pull junkyard, just be sure to get the VIN so you can easily get the code.
Very, VERY useful info for when I go pick up the new one at salvageerikv11 wrote:If you know the VIN of the car the radio came from, you can get the code here:
Thank you!!
- Year and Model: Many Volvos
- Been thanked: 76 times
Getting the VIN will usually help but I typically take the radio into the parts counter and let them look it up off of the numbers on the radio itself if I buy one without the code. I don't think that a single one of my Volvo's actually has the radio in it that shipped with the car but then again I have the code written on the side of the radio with a Sharpie on all of them. Most of them out there have the code written down on them if the previous owner ever had to change a battery and go through the hassle of getting the proper code. I had one where they wrote the code down and then used white out on top of the area that they had written it but on mine I don't even try to hide it. Volvo radios aren't exactly a big item at the Pawn Shop or on Craigslist.
Any hand written 4 digit number on the radio will usually be the code.
- Has thanked: 2199 times
One point no one has made. If you see an SC-900 or 901 radio (they have the built in 3 CD changer) you will need the additional harness and amplifier as neither of these units have a built in amp.
The amp is under the passenger seat or in older (98 and older) it may actually be behind the radio itself.
You will need the additional wiring harness to connect the amplifier. The harness connects to the non-amp wiring blocks from a regular radio, run down to the amp and back up to the radio. To remove it you need to remove the center console.
Radios swapped. New bulbs put in. Got the radio code.
Everything works 100%
Thank you guys
-Noe
Thank you guys
-Noe
- 2066 Views
Last post by FLXC90
- 1786 Views
Last post by BEJinFbk
- 792 Views
Last post by thohurst
- 3135 Views
Last post by precopster
- 1070 Views
Last post by jbkeene
