Here's one I've never seen before....
My roomie's 2002 XC70.
Car has oil from the engine back on the passenger side which somehow managed to make it up the back window.
Here's what she said happened.
Driving home from work tonight stopped to take a phone call. For unknown reasons she decided to check oil because the oil light had come on, and she noticed it wasn't registering on the dip stick. She put a litre of oil in and still not registering. Decided to chance it and drove it home.
It made no sounds, and there doesn't seem to be any smoke coming from anywhere, but you can see oil dripping from the bottom passenger side.
Any thoughts?
Anyone seen anything like this before.
Oil all the way under and up back window... 2002 XC70
- Has thanked: 17 times
- Been thanked: 35 times
Turbo return line has broken loose. This is the signature symptom of that. If you add oil and keep driving it won't matter, it will all leak out from there until you get it fixed. It's not that hard to fix either. This happened to me once driving home from Nashville..had to stop every 15 minutes to add oil to limp home...stopped at a Walmart and bought a jug. Once I was home I fixed the silly return line the next day but the back of my car was covered with oil. If you can avoid driving the car at all, please do. If your engine goes completely dry we're talking about a seized up engine and a totaled car!!
JeffHicks
- Year and Model: 1989 240 Wagon,
I had almost the exact same thing with my '02 XC70. It was the front (passenger side) intake cam seal. It had come completely loose, and was literally pouring oil out of the engine. Driving it for a couple miles, at highway speed, totally coated the underside or the car and blew it up on the back hatch.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
- Been thanked: 4063 times
That can easily be a $4000 chance she took..She put a litre of oil in and still not registering. Decided to chance it and drove it home.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Turbo is on the other side. I agree this sounds more like a pushed seal because of clogged PCV.MadeInJapan wrote:Turbo return line has broken loose. This is the signature symptom of that.
Ah, wrong side for the turbo...then engine seal or it could be an oil return line that has broken. Either way, it needs immediate attention. What was it, original poster?
- 2782 Views
Last post by MDK
- 1877 Views
Last post by CIK7
- 1709 Views
Last post by rollin_home
- 15 Replies
- 3602 Views
Last post by GreenMagicMan
- 1481 Views
Last post by Clemens
