Hi all,
I came across a couple of pictures on the web for S70 and XC90 oil coolers and XC90 one seems thicker than the other. Now I haven't done any research on part numbers or anything yet but from the pictures they look alike, except the size difference. I'm hitting the junkyards tomorrow and I'll be pulling both coolers from both cars to compare and if they are identical as far as fitment, I'd say that would be a good upgrade (will measure fluid as well) for a bit more cooling.
Not that it is a huge difference but if they fit, why not? Reminds me the Ford Probe years where owners would come up with bigger oil filters using Corvette ones and that was double the size of the OEM one.
Anyway, has anyone messed with them in the past?
S70 and XC90 oil coolers, maybe upgrade?
- RigsPGT
- Year and Model: Red 99 S70 T5,
- Been thanked: 2 times
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I have not but if the XC90 cooler fits go for it. Its always nice to help the engine stay a little cooler.
- RigsPGT
Can't wait to go to the JY tomorrow as last time I was eyeing on an XC90 mostly for the transmission cooler and turbo but I will explore the options
- Has thanked: 311 times
- Been thanked: 817 times
Off topic but if you are picking a 5 cylinder XC90, it likely has the R exhaust manifold which is a great upgrade for your turbo car, flows better than either of the P80 ones and the fins don't crack.
If it looks like the one on the left, grab it:
I'm not sure about the heat shield with an R manifold, I would grab the one on the XC90 if it is there. Virtually every turbo S60 has this manifold, too (not just S60R models).
- RigsPGT
- 1646 Views
Last post by Caffeind
- 5583 Views
Last post by jonesg
- 478 Views
Last post by darrylrobert
- 1070 Views
Last post by kahl
- 1582 Views
Last post by carboncow
