I have the stock v70r exhaust...well its the dual so i assume not original to the car so 99+ i guess?
Anyways, i'm getting only exhaust coming out of the right side outlet, literally none coming out of the left side. Is this typical? Is there any way to even this out?
98 v70r exhaust flow - one side?
- Has thanked: 2215 times
- Been thanked: 1853 times
How have you determined that you are only getting exhaust out of the RH muffler? Have you put your hand against the muffler (careful it can get hot!) or put a sheet of paper behind the tip to see if anything is coming out? I have a 2000 R and I do notice I get more moisture (steam) from the RH muffler over the other. My assumption is it takes longer to dry out the condensation as it takes longer to warm up.
Otherwise, if you have tested it, for flow, then someone may have had a dummy muffler made up to look like a dual muffler (no longer available new), or it is somehow blocked.
- 5821 Views
- 6902 Views
Last post by xHeart
- 1012 Views
Last post by odaikorob
- 11 Replies
- 7768 Views
Last post by Sufbug
- 620 Views
Last post by treestone27
