96 850 upper engine mount installation question
2forty
Year and Model: 850 1996
Been thanked: 2 times
Post by 2forty »
Does it matter which side you install the upper engine mount as long as the arrow is located correctly?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
No. I think it is easier from the airfilter towards the passenger side. But easy is not a word i like to associate eith this job. If you go the vice clamp route: bring really big ones. If i had to do it again i'd use pu bushings over stock cuz they don't rhave to be pressed in.
1996 855 R,
2010 V70 D5,
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
I used PU bushings, Installation was relatively easy. It adds some vibration to the steering wheel and inside.
Anyway I had to remove the whole bracket from the engine to get the old mount out... no idea how you could do that without removing it.
850 T5-R '95 auto Image
