I am hoping I can get some advice here. I have a 1995 850. About a year ago, I suddenly had a loud grinding noise coming from my brakes. It only happened in hot weather and when the brakes seemed to be hot. Also, it only happened when I was coming to a final stop, like the last 10-20 feet. I took my car to my "trusted" mechanic. They diagnosed it as being my front pads and rotors, so they replaced them (they also felt the front vibrating.) When I got the car back from them, the same noise was happening! So, I took the car back to them. They kept it for the whole day and said, they didn't hear anything? They said they checked everything, including the calipers, and said everything is fine and the brakes are working well. So yeah, NOW the brakes seemed okay after I got it back the second time. I know they did something to fix it, but they denied it ever happening, so I have no clue what they did to fix it.
When I got the car back, the weather was starting to cool since it was nearing winter (Aug/Sept. 2015). My winter weather is like 70's during the day, and during this time, there was no grinding. It's now starting to get hot again, and sure enough, that grinding noise is back, but not as bad as the first time a year ago. Again, it is only when the brakes heat up and I come to a final stop. If I break lightly, it won't make that noise, and it takes me driving for about 15 minutes for the grinding noise to start (it sounds like metal on metal.) Also, I don't feel the vibration like I did a year ago. I only drive the streets, and have not been on the freeway since I got the new brakes.
I need help because I really don't want to go back to that mechanic if I don't have to. Could it be the pads needs breaking in, or did they put cheap pads on? Should I go back to them? I want to be prepared in case they tell me again they "didn't hear anything." I'm assuming there is some kind of warranty?
I've been searching the web for several days now, and really haven't found an answer except for, it might be from cheap pads.
Any advice will be greatly appreciated!
Thanks!
