Did you know? 🤔
2004 S60 CEL P0192 P0171 FPS 30756098 Topic is solved
2001 - 2007 XC-70
AT-JeffT
Year and Model: 2004 S60 2.4i
Has thanked: 0
Been thanked: 0
United States of America
AT-JeffT
Post by AT-JeffT » Wed May 04, 2016 8:32 pm
Hey All,
Just wanted to post about a recent issue I just had with a new-to-me 04 S60 2.4i
Car was driving excellently, without issue. No hesitation, stumbling, anything. But thew a CEL. Codes P0192 (Fuel Rail Pressure Sensor -low) and P0171 (Lean)
There was a recall on the Fuel Pressure Sensors on 03/04 S60s so I figured that would be causing both codes.
Replaced it with the $34 Rock auto Bosch 0261230109 and the CEL hasn't returned(2 weeks).
Just wanted to share my experience as I didn't get much info from 'P0192' searches. Hopefully this will help someone.
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
DeadEric
Re: 04 S60 CEL FPS
Post by DeadEric » Wed Apr 17, 2019 7:38 am
P0171 "should not" be flagged by a fuel rail pressure sensor. I use quotes because p0171 is usually flagged by O2 data and/or fuel trim data, I'm not fluent in the logic behind fault on this car. Both of those codes would point me in the direction of the fuel pump and testing it. A clogged fuel filter makes the pump work harder and leads to pump burn out, so make sure that's been serviced. If you have access to fuel trim data you should always be rich at wide open throttle.
Hope this helps
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Re: 2004 S60 CEL P0192 P0171 FPS 30756098
Post by abscate » Wed Apr 17, 2019 8:36 am
Added part number to title for search
By the way
$200 for the Volvo one, $44 for the Bosch one from FCP - good price from Rock Auto above!
Probably a good junkyard part to scavenge too.
Link To Volvo Glossary
