2001 T6 ETM replaced but no luck
Replaced etm with xemodex but still has the same problem. Also replaced MAF. Will start, but surges and then stalls when put in drive. Same problem before xemodex replacement. Wondering if anybody had same issues and if so what could fix it. Thanks.
precopster
- Year and Model: Lots
- Been thanked: 128 times
When you sent XeModex a unit to rebuild, was it your own and suited the car?
They may just clone what you send them without a VIN check to see that the firmware is right for your particular vehicle.
With ignition on and no cranking does the ETM start up then turn off in under 8 seconds?
You really need a code reader and preferably a Dice to read your particular car; most other code readers can't see all the codes. A $450 XeModex diagnosis could have bought a fine scanner and some loose change.
- 2128 Views
Last post by BrickBetty
- 4330 Views
Last post by donc
- 55 Replies
- 21643 Views
Last post by andrewgabler
- 2625 Views
Last post by Chuck W
- 27 Replies
- 6298 Views
Last post by xanthefin
