volvo v50 t5 turbo pipes
petermario
Year and Model: 2006
Post by petermario »
I put my turbo pipes wrong from the turbo valve solenoid. So can someone help me with a proper diagram of the pipes installations. So the car has got no power and its smoking every time I start . I see oil on the exhaust
:cry:
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I suppose you are talking about hoses rather than pipes? A pipe would be the intercooler pipes (turbo to intercooler to intake manifold). The turbo valve solenoid is a clue...yes, you don't want to get those mixed up. Let me see if I can find a diagram for you.
I hope that this helps...just check the way it is turned in the picture and where those hoses go!
S40 Turbo Control Valve routing.jpg (44.04 KiB) Viewed 4419 times
petermario
Thanks man . But where does the one coming from the intke manifold go onyo the turbo side?
gswede
Year and Model: 850 R 1997
Post by gswede »
The one from the intake goes to the CBV.
On the TCV there are three colored ports.
Red- Goes to turbo hotside (tight as hell down there on the underside of turbo)
Yellow- Goes to WG
Blue- Goes to nipple on top of turbo, cold side.
petermario
Thank you. Im gonna check it now. But could this has been the reason why my car is having oil in the exhaust and smoking whenever I start then it stops and when I change to 3rd gear. I see a trail of smoke then it goes. Im worried because I just put in a new turbo core
cartridge
gswede
Post by gswede »
Have you rebuilt the turbo, more info please?
If so I suspect that the oil your seeing comes from the turbo..
petermario
Yes I put in the new internals . The whole turbo core catridge
petermario
Turbo core cartridge k04
d8BOtw7ngJFId_oq97co7mQO670VibEbvRa-5lkZI63qSyirSVTJYId8kPQFtKNMpAmKKwoo6bX3ib-Co6Z6FE2rqu4Zda2tV4dLwHnNusFjw7Zv_VJx4rc=w225-h169-nc.jpeg (7.33 KiB) Viewed 4343 times
Ah, let us know if re-routing the hoses correctly made a difference. If not, then I would say the core cartridge was bad or you didn't install it properly. Is it turning as it should?
