Coil pack screw
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings . What size are the screws that hold coil packs in place ?
- Has thanked: 17 times
- Been thanked: 35 times
Not sure of the actual screw but all of mine have been 10mm bolts.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
j-dawg is right, 10mm M6 screw, aprox 1.25" long will do.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- Been thanked: 4064 times
Important they are clean and tight as they ground the high voltage part of the coil.
- Been thanked: 504 times
Are you sure?
I thought the 10-mm bolt is only for anchoring the coil down.
The grounding process is via the threads in the spark plug itself.
The plug grounds through the thread, correct. The ground side of the coil that. Generates the spark goes through the attach screw..if you flip the coil over you will see the attach point is copper to make good contact with the engine block
- 809 Views
Last post by huzzsaba
- 2791 Views
Last post by June
- 1776 Views
Last post by wizechatmgr
- 15 Replies
- 6524 Views
Last post by mecheng
- 2354 Views
Last post by jimmy57
