Warning light shows 'Parking assist service required'....Will I be lucky enough for the problem to be a simple fuse ? Or as per my life story the problem will be more complex. How would you diagnose / solve the problem.
Thanks.
2006 XC90 Parking Assist.
- mydamnvolvo
- Year and Model: Lots
cantgrumble wrote: Or as per my life story
I feel your pain. I have two v70 xc's and one stalls and one overheats. First, I am guessing your car was never lifted, correct? Second, I am also guessing that you cannot see any visual damage to the sensors. Also, when you put the car in reverse, does it constantly beep, or does it not work at all?
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
cantgrumble
- Year and Model: 2006 v70
Hello....thanks for reply....The car has never been lifted, and the 'beeper' does not beep when put in reverse or about to hit a brick wall.
Hope this helps.
Hope this helps.
- mydamnvolvo
So it is probably not too damaged, if at all. It might just need to be reset/recallibratedcantgrumble wrote:Hello....thanks for reply....The car has never been lifted, and the 'beeper' does not beep when put in reverse or about to hit a brick wall.
Hope this helps.
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
cantgrumble
Thanks for that,
Well it is not the fuse,I have ruled that out.
When you say reset/recallibrated dies this involve a garage with diagnodtic equipment and how expensive is the job likely to be.
Thanks.
Thanks.
There are 4 rear park sensors on the rear, yes ?
They may need ALL replacing (you can use Land Rover parts or Ford,as they are the same) or your ECU, situated behind the rear left interior 'turns' surround. Its a black box. Sometimes the wring loom goes faulty too. Id start with replacing the sensors as they are the cheapest.
Do you have access to VIDA to check the fault codes ?
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I agree with Colinbos - if you can, read out the fault codes and see what the car thinks the problem is before just randomly replacing parts.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 272 Views
Last post by ZambiDozer
- 20 Replies
- 8841 Views
Last post by grzeniov14
- 755 Views
Last post by turtle8014
- 478 Views
Last post by Ibro
- 4885 Views
Last post by ALF1
