Camshaft shifting angle exhaust high
AMDFan
Year and Model: 2005 Volvo S60 2.0T
Post by AMDFan »
Hello,
I had an oil change on my 2005 S60 2.0T. I've changed from Mobil1 5W30 to Motul Eco-nergy 0W30.
After the mechanic changed the oil the check engine light came up.
I went back to the mechanic and the error code was: "Camshaft shifting angle exhaust high"
After the engine starts, the angle position should be 0° but its around 5°
On higher rpm (4000+) it goes to the expected 0° value.
The mechanic changed the exhaust side camshaft solenoid. Just to be clear, this is the part I'm talking about:
but the error code remained. Do you have any idea what should we check next time? Or did you have any similar problem?
Thanks in advance for your help!
AMDFan
Post by AMDFan »
Hi guys,
any idea?
Thanks!
