Cigar smoke VS vac leaks
gswede
Year and Model: 850 R 1997
Post by gswede »
Noticed the engine running slightly rough, more soot on tailpipe and lowering MPG.
No fault codes stored.
Lit me a good quality cigar
Disconnect pipe from filterhousing, used clingfilm to close of the end, used the hoseclamp to get a good seal.
Connected a piece of hose on one of the nipples on the plastic hose
Huffed and puffet some smoke, found it coming out the foam insulation around the thick PCV pipe going to PTC
Cut off some of the foam insulation and found the pipe cut clean off.
Used a 4" fitting rubber hose and connected the 2 ends.
Back to running gooood :-)
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Any idea how that happened? :O
- S
[Sold] '97 S70 T5
gswede
Post by gswede »
No, not really. The hose just cuts clean off. I`ve seen other having the same issue in exactly the same spot. Must have something to do with manufacture. This hose is not subject to mechanical stress other than heat cycling.
Ohh and BTW, the hose was only 2 years old, from when I last changed the PCV.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Love it.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Cheaper than a smoke machine! These older plastic PCV hoses to the PTC aren't very well made.
Has thanked: 1609 times
Been thanked: 4065 times
Don't forget to finish that cigar to celebrate...
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
gswede wrote:No, not really. The hose just cuts clean off. I`ve seen other having the same issue in exactly the same spot. Must have something to do with manufacture. This hose is not subject to mechanical stress other than heat cycling. Ohh and BTW, the hose was only 2 years old, from when I last changed the PCV.
Back in 2007 or so when I did the full PCV replacement, the only fault I found was the rigid plastic pipe, inside the foam surround, had simply broken. I think it was the small rigid pipe. That was it! No clogged box, ports, PTC, lines, etc. Damn thing had snapped inside the foam tube. Only smoke would have found it. I like the idea of replacing that rigid plastic line with copper pipe.
That ought to do it......
M1 10W-30 HM
sleddriver
To: gswede,
After reading your post and watching Robert's video, I decided to fire up my smoker to check mine. I did the full PCV about 8 yrs ago and remember the cracked pipe. I also opened the throttle and kept it open & plugged the small hole in the bottom of the intercooler. Afterwards it all pressurized as the bag over the intake pipe puffed out, smoke poured out when the oil fill cap was removed and the dipstick raised. Never saw, nor smelled any smoke. Even the rubber elbow on the pass. side of the IM was fine. That was a relief!! This car has kept me plenty busy tending her lately.
M1 10W-30 HM
