'ABS / Brake Service' Alert
anfranco60
Year and Model: 2001 V70 T5
Post by anfranco60 »
New purchase of 2001 V70 T5 2/16. Rear brake pads were @ 3mm and bought new replacements but haven't got around to the install.
This morning 'ABS / Service Brake' alert was on and no Cruise control. All other dash read functions were good.
Does system sense pad thickness to set this off? Will install pads & check all ABS connections today.
"Bueller?" anyone. . . . :D
Anfranco
Have owned & repaired;
62' 544 w/ B18 engine
66' 122 Wagon
4 - 240's
4 - 850's
DD - 2001 V70 T5
anfranco60
So just left work and alert was gone from dash but still no Cruise control.
Anfranco
66' 122 Wagon
4 - 240's
4 - 850's
DD - 2001 V70 T5
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
anfranco60 wrote:New purchase of 2001 V70 T5 2/16. Rear brake pads were @ 3mm and bought new replacements but haven't got around to the install.
Usually those lights comes on when there is brake failure or low brake fluid in the reservoir. I would check that first.
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Also look at the reluctor rings at front wheels, they rust and even crack
Has thanked: 1610 times
Been thanked: 4068 times
The loss of cruise control is telling you there is a fault in the wheel speed sensor, most probably.
If the fly by wire cars lose any where speed inputs, the software turns off cruise control as a safety mechanism
anfranco60
Serviced rear pads and checked & cleaned all ABS connections.
Problem solved. . . . merci
Anfranco
66' 122 Wagon
4 - 240's
4 - 850's
DD - 2001 V70 T5
