I am replacing a front hub on the '94 850 black Wagon I had bought last summer.
I Need to pick up the E-torx socket for the hub bolts tomorrow.
Can someone tell me what size it is so I do not have to buy a set?
Thanks.
Hub E-Torx Bolt size.
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
Thanks.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
A full set from E6 to E16 cost less than $10 and there are several locations that use them. My guess is that you will pay as much for 1.
Ben850
On my way to Harbor Freight now.
I've got spare bolts if needed.
Ben850
Thanks Steve. I think the new one comes with them, but I'll keep that in mind.
This is the '94 N/A Wagon I've had in storage until last week.
It needs a little cleaning up, but the drivers front hub bearing was the only thing keeping it off the road.
Oh, the wheel speed sensor ring was taken off completely so I have a new axle as well.
The hub bolts turned out to be E-16.
No matter, I had to get a salvage knuckle. The original bearing is welded inside.
- IMG_5232.JPG (194.27 KiB) Viewed 2664 times
My left Hub tapped out with light hammer. The right needed a hydraulic press.
Looking good !
Looking good !
- 1908 Views
- 12 Replies
- 3701 Views
Last post by JimBee
- 2391 Views
Last post by [email protected]
- 1892 Views
Last post by Mikaro07
- 1892 Views
