Hi,
my cruise control does not work - never did since I own the car. Sometimes, when I try to switch it on, the car will apply a little bit of throttle, but only at low speed, for short.
I tested the system according to the 850 work shop manual I found here. Using jump wires, I can switch pump and relay. The gas pedal moves, but not very strongly, or at least pretty slow and weak. Once displaced, it will stay where it is for more than a minute - vacuum seems to be tight. Press the brakes, and the gas pedal jumps back to idle - brake switch ok.
So this seems to be fine. I wonder if the pump is simply too weak. If I feel the vacuum it creates, it's pretty weak also. Way less suction than on the manifold vacuum lines, for instance. Is the pump supposed to have more power?
And if so, I wonder if it is repairable. Anyone opened and tinkered with one of those before?
Thanks, Caspar
Cruise control vacuum pump
- Year and Model: Many Volvos
- Been thanked: 76 times
That sounds like a candidate for a pick-n-pull replacement. They typically run forever so I a junk yard version is pretty low risk.
There is, by design, an open port on the pump and many people freak out about it. Double check that someone didn't put a plug on that port thinking that they were plugging a vacuum leak. That port is where the pump exhausts air to draw the vacuum.
1337
- Year and Model: '18 VW Golf 1.8T 5MT
The pumps also go for about $30 on eBay (used), if you're not in the mood for a trip to the junkyard.
To test the rest of the cruise vacuum system for leaks, you can connect a Mityvac or other air pump to the vacuum line running from the cruise control pump (under battery) to the plunger above the gas pedal. If you apply vacuum to that line, you should be able to look in the foot well and see the pedal has moved near the floor.
If the pedal doesn't move (or if the Mityvac gauge shows no pressure), you may have other leaks.
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
- 12 Replies
- 5861 Views
Last post by 1337
- 1049 Views
Last post by dyn blin
- 1703 Views
- 475 Views
Last post by Andrew Vanis
- 1211 Views
Last post by Ozark Lee
