Could this be something in the ABS controller?
I had to change out the original but the replacement was not in the list of part numbers for a 2000 V70XC.
The tires are correct. So they are not the culprit.
I noticed the descrepency when passing through a few speed monitors on the highway.
Speedometer reads 10kms fast.
- 57gretsch
- Year and Model: 2005 XC90 T6
- Been thanked: 2 times
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
- Has thanked: 2199 times
Do you still have the original? You can get them re-built fairly cheaply. Contact Matty at Mid-West.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What dimensions are they?57gretsch wrote:...The tires are correct. So they are not the culprit.
My car,for example,came from the factory with 205/50/16 on Persus wheels.
There were variations with 195/60/15...195/65/15 or 205/60/15,dependable of market.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
It isn't your abs module. More than likely it's the roadside radar deals that are off.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 57gretsch
Didn't think so.
The tires are Spec according to the plate in the fuel access. Those are on Terra rims which are also Spec for the XC. I don't suppose deer whistles will defeat the radars
- misha
I think in that way too.Matty Moo wrote:It isn't your abs module. More than likely it's the roadside radar deals that are off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Have someone follow you and check the speed in another car. If they are both out by 10kph then the radars are likely off!
Matty Moo
I always speed up when I see those in an attempt to set some sort of imaginary high score as long as it isn't in a residential area.
2000 s70 GLT
2014 Ram
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
In any car speedometers have a positive measurement deviation in about 5-8 percent. In this way manufacturers prevents drivers from exceeding speed limit. Also, there is a correction value for tyres size stored in instrument panel. Surely, this value should match to real tyres size.
If my English is bad, please correct me
