Hi together,
After my 850 did quiete good the last months I now have problems with my cooling system and the engine I guess.
What happened?
I was driving 3 weeks ago to school and my lower cooling pipe was bursting into bits and pieces. I got it replaced and since then I loose lots of coolant. I checked with a block tester at an indipendent shop and he was indicating that I get exhaust gases into the reservoir (color of the liquid changed).
Since then I recognized the following behavior:
- in the morning when the engine is cold I have no coolant in my reservoir
- engine starts smooth
- no white smoke comming out if the exhaust
- after engine is hot the coolant level in the reservoir is at the min mark and the system is under pressure
- sometimes the temperature is rising but not always. I also pull over and let it cool down for some minutes.
- when I open the cap the coolant is boiling and start to overflow
- when I dont do anything the coolant level is for around an hour at the same level and starts dropping after that during the night
So far I tried my luck with head gasket seal (K-Seal). Doesn's seem to work so far.
I was reading some stuff about the head gasket issue and people discribed that they have either oil in their coolant or that the engine starts rough with smoke during the first start. I dont expirience anything of this but something is still going on.
Any suggestions or thoughts?
Oh no...Head Gasket?
volvofornia
- Year and Model: '94 850 T5
'94 850 T5 - 150k Miles - hopefully soon daily driver
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
in the morning there should be coolant in the reservoir. Between min and max. It doesn t have to be at the exact same level everytime but it should be between min and max.
Also, it is normal that it overflows when opened as soon as it is hot.
Have you replaced your thermostat?
Try to get the fluid level to where it should be and then see if it still gets too hot and loses water. If it does you might be in trouble.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
volvofornia
Yes, I replaced the thermostat with a genuie one 4 months ago in January. I just wonder where all the fluid goes? I dont have any signs where it goes. It is not under the car, not in the oil so where else could it be?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Exhaust gases into the reservoir (color of the liquid changed) would indicate head gasket. If you pressure test the system you'll find if there is a leak elsewhere.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 311 times
- Been thanked: 817 times
Everything you describe suggests blown head gasket. For example, there is no other way to get exhaust gases in the coolant.
It's going to need a head gasket job or a new engine.
- 18 Replies
- 5858 Views
- 487 Views
Last post by erikv11
- 3399 Views
Last post by rspi
- 1748 Views
Last post by goddess357
- 1031 Views
Last post by Ozark Lee
