1994 850 base. Radio no sound...
Hello wonderful volvo community. So I did a lot of searching and didn't find what i am looking for. Radio turns on and seems to be working fine. However, no sound at all. I pulled the radio and it has no amplifier. Wires look good and connections are tight. What else can I check? Is the radio shot? Thans so much!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Check them for power.
You can measure voltage while they're in place using a meter.
The small metal nibs on top should both be hot with the key on.
What about cassettes and CD? Any sound from those sources?
End of the day, though, you may just have a dead HU.
- Has thanked: 2199 times
Replacement HU are cheap at PnP yards normally. When on sale I pay about $15 for a SC-816 unit. Get the VIN # for the car as it makes getting the radio code easier. If you find a SC-900 or 901 unit with the 3 disc changer built in, you need to get the amp (under passenger seat or behind the radio) and the connecting cable.
Glad you got to the bottom of the issue. I am hearing of more and more of the old head units failing as well as the amps on the units fitted with them. I guess age is catching up!
- 2125 Views
Last post by SonicAdventure
- 17 Replies
- 4873 Views
- 17 Replies
- 1880 Views
Last post by JRL
- 2120 Views
Last post by BEJinFbk
- 5660 Views
Last post by JimBee
