Hi Folks,
I have an 2007 s60 turbo where the rad fan stayed on high this winter. I installed a new thermostat & sensor in housing, nope.
So for the cold It's been unplugged. This the plug has the magenta wire (where I read changes pwm per required fan speed).
I took it in to have it diagnosed came back with needs new fan (as they only sell whole units, used here are not found).
So I shelled out 600 for the fan and the day i fired it up with new fan unit worked briefly.
What triggers a fan on high, no signal or as i read 10 ms or 20 ms at 100 hz.
Thanks,
Keith
2007 s60 Rad fan on high
Hi Folks,
I have an 2007 S60 turbo where the rad fan stayed on high this winter. I installed a new thermostat & sensor in housing, nope.
I took it in to have it diagnosed came back with needs new fan ecu (as they only sell whole units, used here are not found).
So I shelled out 600 for the fan and the ecu, relay i fired it up with new fan unit worked briefly.
What sensors trigger a fan on high?
Thanks,
edited May 26 12016
hoping for a response...
Thanks,
edited May 26 12016
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
Check your A/C is charged. My 2005 has been doing the same thing for months (waiting on a relative to remember their HVAC vacuum pump to recharge system) since I replaced condenser.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- 273 Views
Last post by darylrobert
- 727 Views
Last post by whilst
- 1442 Views
Last post by francisp
- 13 Replies
- 2792 Views
Last post by jenkinskg
- 13 Replies
- 2091 Views
