1996 850 Wagon with ECC: I think I know the answer to this...
s2zeller
Year and Model: '18 S60
Has thanked: 1 time
Been thanked: 2 times
Post by s2zeller »
I've posted off and on over the years about problems I've been having with the Electronic Climate Control in my 850 GLT. After cleaning out the dials in the ECC dash unit, it was working flawlessly for about 6 months.
Now it is blowing different temperature air out the left and right sides as well as blowing hot when set to 64 F and cold when set to 84 F.
I'm taking an (un)educated guess that it just might be the ECC dash unit has finally cashed in. :shock:
That said, I'd gladly entertain any other possibilities on this issue.
I haven't pulled codes lately (even tho' the AC and REC lights are blinking), but as I recall the last set were pretty generic. I can do that if any thinks it will change the diagnosis.
Has thanked: 2197 times
Been thanked: 1850 times
Remove and clean the 2 cabin temp sensors behind the grab handles above the front doors. When the clog up or fail they will give you strange behaviour like this.
s2zeller
Has thanked: 1 time
Post by s2zeller »
I'll give those a check, but they were cleaned a couple years (at most) ago.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
That's probably exactly what the codes would tell you (cabin temp. sensors). It still wouldn't hurt to check if you have the means to do so.
s2zeller
Has thanked: 1 time
Post by s2zeller »
I'll try to check codes and sensors on the weekend and report back... maybe I'll be surprised.
