99 v70 Rear hatch lock actuator
skysoljah
Year and Model: 1999 y70 xc
Post by skysoljah »
Hi All,
My rear hatch lock actuator only works when the hatch is in the up position. If I move the hatch down a little bit, the actuator does not lock or unlock. The rest of the locks actuate whether the hatch is up or down. Want to know if anyone has experienced this and to please share the fix.
Thanks
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Likely there is a problem with the wiring that powers the latch. The wiring bundle routes through the hinge and after so many years of opening and closing, wires begin to break down.
If you do a search on this forum you will find many posts about this with pointers, here are a couple:
https://www.matthewsvolvosite.com/forums ... =1&t=60002
https://www.matthewsvolvosite.com/forums ... =1&t=60350
skysoljah
Post by skysoljah »
Thank you!
skysoljah
Post by skysoljah »
Hi erikv11,
Your advice was spot on, I found 1 broken wire and 3 that are held together by the shell, spliced all wires and all is well again.Thank you!!
Post by erikv11 »
Awesome, great you are back on the road and hatching!
:D
